When we retrive the model dimensions in drawing, the zero dimension comes from assemly and all however most of them are not required practically. When retriving dimension if automatically the zero dimension can be removed from one tool or all other dimension will appear except zero dimensionthat would be helful. If user need zero dimension model annotations there shall be other tool or check box in the model annotation field to allow zero dimension.
