CREO4.0
When saving a copy of an assembly the window ASSEMBLY SAVE A COPY displays all components to select reuse or save a copy.
It is possible to add additioanl columns to see e.g. parameters of the components to be reused or copied.
It is not possible to save these settings, with the next Creo start you need to add the wished columns again.
Bettr add a finction to save these settibgs just like save settimngs in the model tree.
