select multiple components together to set the dimension upper bound /lower bound in an assembly
In Creo Parametric, to check for interference in an Assembly by considering the upper/lower dimension tolerances of components, it is now NOT possible to select multiple components to make all their dimensions upper /lower bound. It is only possible to select select multiple dimensions one by one which becomes a tedious task in a large assembly.
The capability to select component (s) to make all their dimensions upper/lower bound will make the interference analysis of assemblies a much faster and easier task.
4 Comments
mender
6-Contributor
I think I'm missing something her.e  I see (in Creo 2): [Analysis tab] > Dimension Boundaries > Upper > Set All.  In part mode, that sets all the dimensions of the part; in assembly mode, it prompts you to pick components to set all their dimensions' boundaries, which sounds like what you're looking for?
SureshPerinjery
8-Gravel
My enhancement request is to enable selection of multiple components in an assembly to make all their dimensions upper/lower bound in one go. At present with the component selection only one component dimension changes even if you select multiple components. For making the dimension upper/lower bound for each component in the assembly you have to go through the process again. please check
mender
6-Contributor
Thanks for the clarification.
olivierlp
Community Manager
Status changed to: Archived
