When we select, we may select part, component, surface, curve etc. We can filter as from the bottom filter. However, the filter need to set every time. I suggest if pressing a functional key could have alter the selection filter that would be great. For example, f2+ mouse click to select surface, f3+ mouse click to select part etc...
Jayanta Sarkar
