set a default measure tolerance different then rough
In part properties it is possible to ask the statistics of the part. For instance weight and volume. The tolerance therefor is by default set to Rough. This is too coarse and can lead to costfull errors. it should be possible to set a default value (eg. 1%). Preferably this is a setting that can be stored in the site or corp customization directorie.
7 Comments
FriedhelmK
Hello Ward,
that you can adjust yourself.
Change the command "Part Measure"
"get_vol_prop :for_part"
in
"get_vol_prop :for_part :TOL :PERCENT_TOL 1"
wdesmet
3-Visitor
Hi Friedhelm
this is indeed a good idea, but it only covers half of the problem. if you demand a report from the part properties dialog box, then the tolerance cannot be set to a value by default
FriedhelmK
Hi Ward,
but it works.
When you call up the dialog box with the modified command, 1% is indicated also in the report.
wdesmet
3-Visitor
yes it is correct, but you are always calling up the Part Measure command. I'm going to Part Properties first>statistics and there i ask for the reportpart+prop+tolerance.JPG
FriedhelmK
Hi Ward,
you are not easily satisfied
If you want you can try
part_prop :display_ui :the_part :percent_tol 1
Best regards
Friedhelm
wdesmet
3-Visitor
I know, but I do appreciate the answer .
And it seems to work!
Thanks for all the efforts.
PTCModerator
Emeritus
Status changed to: Archived
