show NPT pipe taps as tapered in the machining module
NPT pipe taps should be modeled as tapered in the machining module.  A machinist can look at the drawing and quickly tell that the tap is an NPT pipe thread.  Currently, we use a lisp routing to make the tap. however the threads do not automatically show up in annotation, so we add the threads by hand.  This is a waste of time, but necessary for the correct thread representation.
4 Comments
ptc-1796640
1-Newbie
please also see http://communities.ptc.com/ideas/1058 for more thread stuff
BarryCritchley
1-Newbie
Greg, not sure if it is the link or my pc, but the link in your comment above returns "An unexpected error has occurred"
ptc-1796640
1-Newbie
This appears to be an issue w/ PTC's communities site - after I click in the link in my comment above, I notice that the address bar in my browser says "communities.ptc.com/ideas/http://communities.ptc.com/ideas/1058"
In order to actually see the page you have to strip out communities.ptc.com/ideas/ from the beginning, and you should be able to get there.
olivierlp
Community Manager
Status changed to: Archived
