showing a drawing dimension in a specific view
We want  to show in a drawing a dimension of a specific feature selected from Model Tree in a specific view (it was possible in Wildfire4)
8 Comments
AriesChen
1-Newbie
This seems to be an existing function.
Just change the name of the 'Show Model Annotation', and is further strengthened
fperez-2
With the new UI, You can't display the annotation for a spécific feature in a spécific view.
AriesChen
1-Newbie
select feature --> right mouse button --> 'Show Model Annotation'  -> pick a 'view'
In the pick of view, it is recommended to use the filter 'Drawing View' ,
If you choose to feature, will not you need results
fperez-2
if you do :
You will obtain all the annotations that can be display in this view.
And not just the annotation of the feature selected.
Do you agree ?
Thanks for your answer. Fabrice.
AriesChen
1-Newbie
Sorry, I understand
RaphaelCNascime
1-Newbie
The "Show Dimensions by View" command has been brought back as of Creo Elements/Pro 5.0 M200 and Creo Parametric 2.0 M060.
PTCModerator
Emeritus
Mfridman
Status changed to: Current Functionality
The "Show dimensions by view" are a current functionality of Creo . Updating the status of this product idea
