showing a drawing dimension in a specific view
We want  to show in a drawing a dimension of a specific feature selected from Model Tree in a specific view (it was possible in Wildfire4)
7 Comments
Newbie
This seems to be an existing function.
Just change the name of the 'Show Model Annotation', and is further strengthened
Amethyst
With the new UI, You can't display the annotation for a spécific feature in a spécific view.
Newbie
select feature --> right mouse button --> 'Show Model Annotation'  -> pick a 'view'
In the pick of view, it is recommended to use the filter 'Drawing View' ,
If you choose to feature, will not you need results
Amethyst
if you do :
You will obtain all the annotations that can be display in this view.
And not just the annotation of the feature selected.
Do you agree ?
Thanks for your answer. Fabrice.
Newbie
Sorry, I understand
The "Show Dimensions by View" command has been brought back as of Creo Elements/Pro 5.0 M200 and Creo Parametric 2.0 M060.
Community Manager
