Creo can not represent a single hole with a pitch circle in the drawing, even when i create it in the bore dialog with pitch and angle.
I have to go through the pattern and then disable the second patterned hole.
Why is this second hole needed to represent the pitch circle in the drawing?
The information is already available in the PRT with 1 hole. You see it in the Dialog PATTERN
