table with repeat region in 3D
in optic of MBD, it was useful to have the capabilities to create some table in 3D with Repeat Region (with the same capabilities of the 2D)
5 Comments
I would love this for cabling, which is heavily dependent on tables.
Community Manager
Status changed to: Under Consideration
Community Manager
Garnet
Visitor
This Functionality is very important to have the ability to use MBD in assembly-lines/assembly-stations without drawings. Currently the drawing is still necessary because of the BOM-Table and BOM-Balloons. Therefore this request is also affecting Creo View, which should also support this functionality by using the pvs/pvz-export.
Maybe a splitted view with the Model on one side and the BOM-Table on the other side can rout to a useful solution.
BTW: we use Component-parameters with our BOM-Tool (Toolkit) to save the position-numbers or other parameters permanently to the model. The Component-parameters can be used by notes with the syntax &POSITION:att_cmp, but unfortunately not for custom-symbols.
