3D model (.prt) : tolerance on the EDGE
-> 2D drawing (.dwg) : POSSIBLE to move the tolerance on the drawing (see video)
3D model (.prt) : tolerance on the SURFACE
-> 2D drawing (.dwg) : IMPOSSIBLE to move the tolerance on the drawing (see video)
It should be possible to move a tolerance on the drawing when it's positionned on a surface in the 3D model !
