why not automatically add minus("-") in ordinate dimension?
It is not good enough when we created ordinate dimensions with 2d drawing. Because Creo drawing cannot automatically add  minus("-") with ordinate dimension when Origin locates at right side or upper side. We have to manually added "-" as prefix.
Hope 2D drawing have this kind of function.
3 Comments
Dale_Rosema
You may want to vote on your own idea.
BenLoosli
23-Emerald II
The system should put negative signs '-' in front of all dimensions that are not in the 1st quadrant and are in the negative direction from the 0,0 origin. This should be automativ with no user modified text required.
olivierlp
Community Manager
Status changed to: Archived
