05 - Multibody - Windchill 12 & Creo 7.0.1
mneumueller
Hello Multibody community!
Welcome to a second post on multibody capabilities added in Creo 7.0.1. What I had not yet been fully covering in the last post was how Creo & Windchill interact as it relates to the multibody concept.
So, here a summary of Multibody support for Windchill & Visualization
  • General behavior
    • Multibody parts are managed similarly to single body parts, bodies are not exposed
  • Windchill versions prior to Windchill 12
    • Body designation information is ignored when connected to a Windchill Server version not supporting body designation yet
    • Publishing of multibody parts to Creo View is supported since Creo View 6.1 (including exposure of bodies to Creo View)
  • Windchill 12 & Creo 7.0.1
    • Support of Body designation, including
      • Transfer of Body designation information from Creo to Windchill for models containing designated bodies
      • WT part creation for designated bodies if BOM Designation is set (.prt, .asm)
      • IBA mapping & propagation for body materials and mass property parameters
        • Note on Windchill configuration: those attributes have to be added to the Body (under Model Items) type definition. They need to be part of the type definition similar as typically being done for the CAD Document type.
Here is a quick demo of the above capabilities
Back to Creo 7.0 Multibody Home: Start Here!
Enjoy!....Martin
9 REPLIES 9
Matteo_1987
(To:mneumueller)
In addition to the steps shown in the video, is it necessary to set preferences in Windchill to view the bodies?
you need add  attribute that you want to transfer them  to the Body (under Model Items) type definition.  They need to be part of the type definition. Otherwise you won't see them with the WT parts.
Matteo_1987
(To:mneumueller)
Where can I find a guide? Because i doing everything the same as the video I still don't see the bodies in Windchill
Ty,
Matteo.
Bodies themselves are not shown in Windchill, but you can have Windchill create WTparts for bodies (and/or  quilts or other items)  if
a) the bodies are designated
b) you specify the ".prt" extension during designation
c) you check "Auto associate parts to CAD documents" option during check-in
Is it possible to create an assembly drawing based on multibodies with balloons, BOM table, exploding BOM?
Yosef
Matteo_1987
(To:YY_8922822)
No, unfotunately it isn't possible.
You could write it in Creo Parametric Ideas.
we don't use the auto association function  in our company.
How could we associate a body to a part in the CAD/Dynamic Documents section by manual?
Thanks.
Balazs
SteveShaw
(To:BalazsToth)
Once a Body has been designated in Creo and the Extension set to PRT and save and uploaded in the workspace, the Edit Association UI will show the Model Items created in Windchill representing these designated bodies.  From here you can associate the bodies to new or existing WTParts from Windchill.
It works fine. Thanks.
