Advanced Framework Extension Tips n' Techniques
No ratings
Check out this video on Advanced Framework Extension from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal)
Comments
Webcast Q&A
Question from Aaron:  Is AFX easy enough to save as and create models/drawings for different material gauges.  i.e.:  US vs European?
Answer:  Yes, there are 2 libraries, metric or English.
Webcast Q&A
Question from Christopher:  Did you answer the library in Windchill question?
Answer:  Yes, but the library is not in Windchill but final models are stored there.
Webcast Q&A
Question from David: Can you take this directly into simulate after?
Answer:  Yes, the info is embedded in the beams.
Webcast Q&A
Question from Karol:  How to open AFX?
Answer:  In an assembly, you should have a tab.  Then create a project.
Question from Karol:  Is there an option to add your own components?
Answer:  Yes
Webcast Q&A
Question from Michael:  Good point about wood construction.  Are there many others using AFX this way?
Answer:  For cabinets, there is a 3rd party tool specifically for that.  https://www.sigmaxim.com/index.php/products/design-process-tools/smart-wood-designer
Webcast Q&A
Question from Thomas:  Is AFX a good tool for regular MFG factory layout design?
Answer:  No reason why not.
Version history
Last update:
‎Aug 15, 2022 02:05 PM
Updated by:
Labels (2)
