In Creo 4.0 it is now possible to append wires and cables to branch bundles after the bundle has been created. If you set configuration option prompt_extract_from_branches then you can control how wires and cables are extracted from a branch
Watch the attached video to learn more
Just to clarify, is this functionality adding the wire segment into the bundle even if the wire does not follow the entire path of the bundle. If so this would dramatically reduce the number of bundle segments that will need to be produced.
Cassandra
Only simple branches are allowed - meaning the wire has to follow the entire path,
cheers, Jim
Has anyone tested the new branch functionality?
if so then
thanks, Jim
