Check out this video on Creo Advanced Assembly from PTC Application Engineers!
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Anonymous: Is skeleton model standard offer or special installation needed?
Answer: No special installation needed but you do need the Advanced Assembly Extension (AAX) module.
Question from Anonymous: From which Creo version onwards is skeleton available?
Answer: Skeletons have been around since Pro/E 14 (back in the early 90s).
Question from Anonymous: How does Windchill deal with skeletons?
Answer: Windchill does not build a WTPart but it does know it is in the assembly.
Question from Anonymous: Can you start with parts and build the skeleton later? It is hard to understand what's happening with the skeleton when I don't see anything.
Answer: Yes, but then you would use it for positioning mostly.
Webcast Q&A
Question from Walter: How can you tell if a part was changed and no longer fits, or interferes?
Answer: Windchill always marks models as modified that have been changed and interferences can always be seen with a Global Interference check.
