Creo Behavioral Modeling Tips & Techniques Session Recording (East Coast)
No ratings
Check out this video on Creo Behavioral Modeling from PTC Application Engineers!
Presenters:  Mark DeCraene (Generalist Application Engineer, Principal), Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Comments
Webcast Q&A
Question from AnandIs Behavioral_Modeler_SET license module similar to the BMX module?
Answer:  Yes, that is correct.
Webcast Q&A
Question from BlakeWhen using behavioral analysis, does the CAD model need to be built with connections, similar to Mechanism Dynamics?  Connections such as springs, dampers, force torque loads, etc.?
Answer:  Only if the assembly you are analyzing is a mechanism.
Webcast Q&A
Question from David:   When doing a more complicated feasibility analysis that has more than a few design constraints or design variables fail, is there an easy way to see what constraint caused the failure?
Answer:  The feasibility will fail but the issue could be with one dimension or the combination of the change of multiple dimensions.  It's best to start small with 1 or 2 dimensions for feasibility and grow from there.
How to get the source model
Translated the below text from Simplified chinese to english using google translate. By community Moderation team.
Simplified Chinese: 如何获取源模型
Version history
Last update:
‎Jul 27, 2021 11:24 AM
Updated by:
Labels (2)
Tags (2)
