Check out this video on Creo Behavioral Modeling from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Jacob: When showing a parameter in a note, I find that the model has to be regenerated twice before the note will update. Is there a way to get the relations to regenerate before the note is regenerated?
Answer: The regeneration process works in the following order:
To avoid having to regenerate twice:
Question from Jacob: Can you use a user created relation parameter as a goal to minimize?
Answer: Yes
Webcast Q&A
Question from John: Can I get the values to show up in the history tree, so I don't have to click in to a given feature to check it?
Answer: Yes, they can be displayed in a column of the Model Tree.
Question from John: Can I change feature names on the fly in an analysis or do I have to go back to the feature to rename, then rerun the analysis?
Answer: You can name it on the fly in the analysis. Just need to press enter once you type in the new name in the analysis window.
