Creo Flexible Modeling Tips & Techniques Session Recording (West Coast)
No ratings
Check out this video on Flexible Modeling from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist Fellow) and Ryan Butcher (Technical Specialist Fellow)
To dive deeper into the subject, check out
Comments
Webcast Q&A
Question from AnonymousIs this functionality included in the most basic package?
Answer:  In the current and most recent package configurations it is.  However, there are older packages that this is not included in.  In that case you could upgrade your packages or simply add the Flexible Modeling Extension to one of your old packages.
Webcast Q&A
Question from BrentWhen you use flexible modeling, how does that affect drawing definition?
Answer:  In the case of moving the rib at the angle, you would easily show the dim for the flex move feature (the 11 degree dim).
Webcast Q&A
Question from Jonathan:  What happens with the original operation when you move it with flexible modeling?>  Does it update automatically or the changes only depends to the move operation?
Answer:  It updates automatically.
Webcast Q&A
Question from Martinez:  Can flexible modeling work with creating different simp reps?
Answer:  Yes, in the use case that you add Flex Features and then include and exclude those features in different simp rep combinations to control the display of them.
Version history
Last update:
‎Jul 20, 2021 02:55 PM
Updated by:
Labels (2)
Tags (2)
