Check out this video on Creo Flow Analysis Tips and Techniques session from PTC Application Engineers.
Presenters: Lino Tozzi (Solution Consulting, Fellow) and Ryan Butcher (Solution Consulting, Fellow).
WEBCAST Q&A
Question from Daniel: Can autoscaling be turned off?
Answer: Yes, the option is - sketcher_auto_scale_dimensions "yes/no".
WEBCAST Q&A
Question from Dominick: Can you remove just the pattern without removing the "base" feature in Creo 9?
Answer: Use "Delete Pattern" and it does just that.
WEBCAST Q&A
Question from Trevor: Can you split a surface using only a line, or does it need to be an enclosed shape?
Answer: Just a line will work as long as it reaches the current surface boundary.
WEBCAST Q&A
Question from Zachary: If you split the surface, can you apply different properties?
Answer: Yes. Try various properties that you might need.
