Creo Generative Design Tips & Techniques Session Recording (West Coast)
100% helpful (1/1)
Check out this video on Generative Design from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist Fellow) and Ryan Butcher (Technical Specialist Fellow)
To dive deeper into the subject, check out PTC University.
Comments
Webcast Q&A
Question from AveryIs there minimum PC performance requirements to use this feature?
Answer:  Yes, and it uses GPU
Webcast Q&A
Question from BrentonWhen it generates a design for additive manufacturing, does it take into consideration the infill lattice structure and percentage of infill?
Answer:  That is not currently available but it is planned for future release.
Webcast Q&A
Question from DerrickCan you mirror the changes you are making to both sides to keep symmetry?
Answer:  Yes
Webcast Q&A
Question from KevinFor secure programs, can we use an internal cluster?
Answer:  It is only available in our cloud solution (AWS).
Question from Kevin:  If you delete the tesselated  geometry, can it be recreated?
Answer:  Yes, simply rerun the Generative Design.
Version history
Last update:
‎Jul 20, 2021 02:46 PM
Updated by:
Labels (3)
