Check out this video on Generative Design from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist Fellow) and Ryan Butcher (Technical Specialist Fellow)
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Avery: Is there minimum PC performance requirements to use this feature?
Answer: Yes, and it uses GPU
Webcast Q&A
Question from Brenton: When it generates a design for additive manufacturing, does it take into consideration the infill lattice structure and percentage of infill?
Answer: That is not currently available but it is planned for future release.
Webcast Q&A
Question from Derrick: Can you mirror the changes you are making to both sides to keep symmetry?
Answer: Yes
Webcast Q&A
Question from Kevin: For secure programs, can we use an internal cluster?
Answer: It is only available in our cloud solution (AWS).
Question from Kevin: If you delete the tesselated geometry, can it be recreated?
Answer: Yes, simply rerun the Generative Design.
