Check out this video on Creo Mechanism Dynamics from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: August 3, 2021
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Brent: If you were given an allowable envelope, can you then overlay your actual envelope on that to compare?
Answer: Yes, definitely. The motion envelope is a part that can be used to do a static interference or clearance analysis in the assembly.
Webcast Q&A
Question from Kevin: Can we use CAS for FEA?
Answer: You can manually transfer the loads into Creo Ansys Simulation. Transferring them automatically is on the roadmap.
Question from Kevin: Which version of Creo is this? 7?
Answer: It is Creo 7.0. These techniques can be done in any of the Creo Releases.
