Creo Mechanism Dynamics Tips & Techniques Session Recording (West Coast)
No ratings
Check out this video on Creo Mechanism Dynamics from PTC Application Engineers
Presenters: Lino Tozzi(Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: August 3, 2021
To dive deeper into the subject, check out PTC University.
Comments
Webcast Q&A
Question from BrentIf you were given an allowable envelope, can you then overlay your actual envelope on that to compare?
Answer:  Yes, definitely.  The motion envelope is a part that can be used to do a static interference or clearance analysis in the assembly.
Webcast Q&A
Question from KevinCan we use CAS for FEA?
Answer:  You can manually transfer the loads into Creo Ansys Simulation.  Transferring them automatically is on the roadmap.
Question from KevinWhich version of Creo is this? 7?
Answer:  It is Creo 7.0.  These techniques can be done in any of the Creo Releases.
Version history
Last update:
‎Aug 05, 2021 09:49 AM
Updated by:
Labels (3)
