Check out this video on Multi-Body Design from PTC Application Engineers!
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Kyle: Would multi-body save the same as an assembly in SAP?
Answer: I believe it will appear as a part.
Webcast Q&A
Question from V: Can you assign a material to a body?
Answer: Yes, each body can have it's own material.
Question from V: Can you also have the bodies populate a BOM on the field of the drawing
Answer: Repeat Region support in Drawings for Multi-body parts
Listing body names, parameters, values, material
Auto exclusion of construction bodies
Display options for PTC_REPORTED_MATERIAL in repeat region
