Check out this video on Creo Parametric Design Automation Tips and Techniques session from PTC Application Engineers and CadActive (PTC Partner).
Presenters: Phil Clukies (Account Manager, CadActive), Ben Bowman (Solutions Engineer, CadActive) and Ryan Butcher (Solution Consulting, Fellow, PTC).
Creo Design Automation Learning
WEBCAST Q&A
Question from Anonymous: Which release of Creo are we looking at right now, with this custom tab? How was the custom tab built? Pro/Toolkit?
Answer: The tab is built with Pro/Toolkit and works with any version/release of Creo back to Creo 4.
WEBCAST Q&A
Question from Carey: Envelopes are not common but should be explained as well.
Answer: We have covered this topic in a past TnT session. Those recordings are available at Community.ptc.com. Look for Large Assembly Management.
WEBCAST Q&A
Question from Paul: Can you have a global config file?
Answer: Yes.
