Check out this video on Creo Parametric Progressive Die Tips and Techniques session from PTC Application Engineers.
Presenters: Lee Goodwin (Solution Consulting, Principle) and Ryan Butcher (Solution Consulting, Fellow).
WEBCAST Q&A
Question from Mark: In terms of designing a part, how is PDX different from Creo Sheetmetal? I've used Sheetmetal but when would i need to use PDX?
Answer: Sheetmetal is the design phase in the process. PDX is for developing/designing the tooling for the manufacturing process.
Question from Mark: Thank you for the last question. Similar to PDX, is there a tool for injection molding die design?
Answer: Yes, Expert Moldbase (EMX).
WEBCAST Q&A
Question from Sandeep: Does one need a separate license for adding the PDX plug-in, inside the already existing Creo toolbar?
Answer: Yes, it is an add-on extension.
