Check out this video on Creo Additive MFG from PTC Application Engineers.
Presenters: Jason Petersen (Solution Consultant, Principle) & Lino Tozzi (Solution Consultant, Fellow)
Original Date Presented: January 18th , 2024
WEBCAST Q&A
Question from Derek: Can the standard hole note be modified or customized?
Answer: Yes, those can be modified/customized. This link should help: https://www.ptc.com/en/support/article/CS28399?source=search
WEBCAST Q&A
Question from Matt: Can you still omit instances?
Answer: Yes, that is still available.
WEBCAST Q&A
Question from Scott: Not sure if this will be covered in the assembly patterns, but I'll submit my biggest question/grip with patterns ahead of time. Often we will pattern groups of components in a higher assembly (i.e. 6 patterns for 6 cylinders on the engine). The issue with patterns is that once a group is patterned, the group cannot be changed. So, I cannot delete a part from a group that is patterned. I'm using Creo 7 but moving to Creo 10 soon. Does Creo have this functionality in Creo 10 or will it be in the future?
Answer: Not with Creo 10. This would be a future enhancement.
Question from Scott: Another feature I'd love to be more efficient with is patterning a table. Any efficiency or UI tips with using that table would be appreciated. The window that pops up to edit the table seems a bit clunky, but maybe I'm just not sure how to use it efficiently.
Answer: There is no new functionality for table patterns. This is a future enhancement.
Question from Scott: Can you confirm what you selected to pattern? I think I missed that. Did you select the Foot_support group from the model tree?
Answer: That was a part. It was all the parts merged into one.
