Check out this video on Creo Render Studio from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales).
Webcast Q&A
Question from Anonymous: What format of Step file will carry these material color properties?
Answer: All, but the color needs to be checked on export. It is was not chosen on export, you can't have it on import.
Webcast Q&A
Question from Ian: I never seem to be able to save the scene. How do you do that?
Answer: Lino showed the option to "save scene with model" under the scene tab.
Webcast Q&A
Question from Juan: How can you apply multi-colors?
Answer: You can apply a different color to each surface.
Webcast Q&A
Question from Oscar: I wonder if an imported (stp or iges) can be rendered easily.
Answer: Yes, provided the surfaces import cleanly.
Question from Oscar: Is KeyShot a separate engine/license?
Answer: The module Creo Render Studio contains the KeyShot engine.
Webcast Q&A
Question from Rajesh: Is it possible to export file with render? If so, please suggest a good format.
Answer: Yes, you can the choice of JPG, TIF or PNG.
Webcast Q&A
Question from Robert: Would showing water in the tank need to be another part in the model that is classified by itself?
Answer: Likely, yes.
Webcast Q&A
Question from Robert S: What material would you use for the best, reflective mirror-like surface?
Answer: You can use any material, but choose chrome.
Webcast Q&A
Question from Thomas: Can we import it directly to KeyShot?
Answer: Export to the KeyShot command.
Thanks for the video post. Can you please allow speed control and/or post to youtube?
If you right click on the video graphics area you can Show Full Controls to change the playback speed.
Beautiful! I didn't know you could do that and missed it when I RMB. Thank you!
