Creo Simulate Advanced
No ratings
Check out this video on Creo Simulate Advanced Techniques from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales).
Comments
Webcast Q&A
Question from PaulHow do you show the live convergence plot?  Can that be shown for normal static study?
Answer:  Yes.  Click here for more.
Webcast Q&A
Question from BeccaDo you have a webinar/examples for the MechT example?
Answer:  Picture two walls and a beam in between.  There is initially a gap but then that gap goes away with thermal.
Question from Becca:   Can you force-refine the contact faces and only the contact faces?
Answer:  Yes, you can specify nodes along an edge and refine face to face for a typical contact.
Webcast Q&A
Question from RajeshCan we set ambient temperate as elevated say 75C and run the analysis?  I believe default would be room temp 23C .
Answer:  You can but i believe that would only effect a thermal analysis.  The properties are not temperature specific with the exception of using a MechT example where thermal expansion eventually turns into a structure simulation.
At 55:35, the mentioned plot is a "real-time tracking of time spent in solving", but not a convergence plot, isn't it? Confused.
Version history
Last update:
‎Mar 01, 2022 02:09 PM
Updated by:
Labels (1)
Tags (1)
