Check out this video on Creo Reverse Engineering from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: January 25, 2022
Webcast Q&A
Question from Anonymous: We have "Shrink Wrapping" feature to align with scanned model?
Answer: This is what was demonstrated with the "Freestyle" tool. Depending on the resolution you choose to use, it will "shrinkwrap" more accurately.
Question from Anonymous: Can we do the project sketch from the initial file and then create the surfaces?
Answer: Yes, one method would be the Restyle/Extrusion tool and the project sketch option as demonstrated.
