Check out this video on Creo: "Things You Might Know, but Probably Don't from PTC Application Engineers. Presenters: Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: September 19,, 2023
To dive deeper into the subject, check out Creo UI Tips.
WEBCAST Q&A
Question from Abby: We'd like to be able to organize the sketches we add to the sketch palette but looks like you can only add one tab. Is that correct?
Answer: If you go to your install of Creo, you can add your own folders to the sketcher palette folder. Here is my location: C:\PTC\Creo 10\Creo 10.0.0.0\Common Files\text\sketcher_palette. Then you can add sketches to as many folders as you like.
WEBCAST Q&A
Question from Joanne: Can you still drag if the sketch dimensions are locked?
Answer: The sketch will not move in the directions that dimensions are locked. You would just RMB and unlock the dimensions. Then you can move freely.
