DFMPro Tips n, Techniques
No ratings
Check out this video on DFMPro for Creo Parametric.
Presenters: Tom Van Der Auwera (HCL), Pranev Khurjekar (HCL), Steve Gerdman (HCL),
Nambi Chandrasekaran (HCL) & Lino Tozzi (Solution Consultant, Fellow, PTC)
Comments
WEBCAST Q&A
Question from Mark:  Are the results for a group of parts able to be aggregated for analysis?  Seeing trends in certain rules to be evaluated?
Answer:  Yes, these trends can be show.
WEBCAST Q&A
Question from Mohammed:  How do the manufacturing rules get updated or new rules added?  Can an org add its own rules?
Answer:  New rules can be added a couple of different ways:
  • Rules can be added through the Rule Development Framework inside the software.  This method can be used by engineers within the organization that has deployed the software and doesn't require any software coding
  • Rules can also be added through our DFMPro services team, which is focused on DFMPro rule development.  In this case the rules will be coded into the software.
  • In addition, rules may be added in every release of the software.  These added rules can come from our R&D team or through specific requests from existing customers,
Question from Mohammed:  Does DFMPro support all variations of plastic parts manufacturing such as standard injection molding, over-molding, multi-layer, water-assisted IM, gas-assisted IM, thermoforming, blow molding, etc.?
Answer:  Rules can be added and tailored to fit multiple manufacturing methods.  Additional rules can be built by HCL.
WEBCAST Q&A
Question from Thomas:  What kind of license options for DFMPro?
Answer:  We currently offer User Based licenses in either a subscription or perpetual model.
Version history
Last update:
‎Mar 29, 2023 09:45 AM
Updated by:
Labels (1)
Contributors
