As you all know Pro/Diagram is being superseded by Creo Schematics. In Creo 4.0 we are restricting access to Pro/Diagram via a hidden configuration option and in Creo 5.0 we will officially retire Pro/Diagram turning it off completely.
To turn Pro/Diagram back on you need to add enable_obsolete_modes True to your configuration file and start Creo.
I tried adding manually the below config option and run the Creo Parametric 4.0 with date code m060. Pro/diagram module is not turned back
Kindly help me if you have any other solutions.It is very urgent.Kindly send a solutions to santhalingam.c@adroitecinfo.com
Please try to set hidden config.pro option enable_obsolete_modes to yes instead of True.
