Enabling Creo Parametric DEBUG logging for Windchill Interactions using Environment Variables
No ratings
Applicable Release: Creo Parametric 1.0 to 8.0
Description:
In this video, we will be enabling DEBUG Logs
  • For Creo Parametric by setting environment variables from Command Prompt window
  • If the CMD window is launched with Admin Privilege (Run as Administrator), the variables will be set as system level. Else, will be set at user level.
  • The user may need to log off and log-in for the variables to take effect.
Version history
Last update:
‎Jun 23, 2021 12:26 AM
Updated by:
Labels (3)
