In this series, our expert product managers are going through how-to Creo tips. Each bite-sized tutorial is less than 5 minutes long. It's a perfect opportunity to learn something new or get a refresher on a workflow you haven't used for a while.
Below you'll find about 15 minutes of video tips aimed at helping you improve your Creo proficiency.
Ready to get started?
When you create external references among features in a design, local references to features in a part, or placement references in an assembly, reference creation and backup tools are provided for specifying system behavior.
In this tutorial, Arnaud van de Veerdonk, Creo Product Manager, shows you how to use Update Control functionality through, on-the-fly created, Geometry Backups.
Watch the tutorial:
When working in model-based definition (MBD), three schemes are available to manage the visibility of any combination state in a model:
In this tutorial, our Creo Product Manager shows you how the 3 schemes can be used to manage visibility of annotations and supplemental geometry, such as planes, axes, coordinate systems, points, and curves.
Watch it in action:
Using section relations in combination with the TRAJPAR parameter, you can create a section whose size and shape vary along a sweep. TRAJPAR, which ranges from 0 to 1 as the section sweeps along the trajectory, is the trajectory parameter used in relation for variable section sweeps.
In this tutorial, Paul Sagar, VP of Product Management, shows you how to build specific types of spiral geometry using the TRAJPAR parameter and a variable section sweep.
See how to do it:
For more tips from our experts, watch the Tips from the Creo Masters main page.
