High Speed Machining Tips & Techniques Session Recording (West Coast)
No ratings
Check out this video on High Speed Machining from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist, Principal) and Lino Tozzi (Technical Specialist, Fellow)
Original Date Presented: September 28, 2021
To dive deeper into the subject, check out PTC University.
Comments
Webcast Q&A
Question from JonHow does cutting a tool debur when cutting leaves a bur?   Is this some kind of special debur tool?
Answer:  Does not require a special tool.  Just go use a ball end mill.
Webcast Q&A
Question from Mark:  Does Creo NC work with all major CNC manufacturers?  Haas, DMG Mori, etc.  Is there a predefined list of machine you can select from?
Answer:  Yes, Creo NC includes g-post and we can support any manufacturers.
Question from Mark:  How about SolidWorks or NX models?  Do they have to convert it to STEP?
Answer:  No need to convert.  Can be native SW or NX or most other CAD models.
Version history
Last update:
‎Sep 28, 2021 04:56 PM
Updated by:
Labels (2)
