How to get overall size X, Y, and Z coordinates of the model using ModelCHECK in Creo Parametric
No ratings
Applicable Releases: Creo Parametric 1.0 to 8.0
Description:
  • In this video, we will be using ModelCHECK to
    • Get overall size of the model
    • Calculate model size as X, Y and Z coordinates
    • Get bounding box of a model
Comments
Creo knows the bounding box at all times.  It just needs to expose these values in the system parameters or a dedicated feature without having to install and run ModelCheck.  (I suspect very few small to medium-size companies have ever attempted to configure and use ModelCheck.)
Here is the corresponding product idea.  It's currently the 11th most requested Creo enhancement on this community (out of more than 4,700 Creo ideas).
https://community.ptc.com/t5/Creo-Parametric-Ideas/Bounding-Box-as-a-Feature/idi-p/574282
V_1
Is there a way to get the X, Y, Z, coordinates of datum points using ModelCHECK? Or within CREO at all?
Creo will do it, no modelcheck needed.
Refer to this thread for an overview.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Measuring-vector-components-of-distance-in-Creo/m-p/757765
Version history
Last update:
‎Dec 07, 2021 03:24 AM
Updated by:
Labels (3)
