Thanks for the video ![]()
Its shows how to install locally, but how do you install on a mapped drive?
I have same problem with network installation, as I create locally installation first, copy-paste the
installation to my network disc and edit *.bat and *.psf files manually.
Regards
Yes, I know this Work around ![]()
But I think it is quit annoying, because we have a lot of different licenses and different startup configurations so it takes a lot of time and possibilities of errors.
I'm sure there must be quit a lot Companies with the same problem, so an easier installation approach would be very much appreciated ![]()
Regards Peter
O.K.
Other way, you can create the installation from computer that doesn't has local installation of Creo 3.0.
Regards
Leonid
Can you please tell me how to download latest creo version ?
You have to log in to PTC Esupport https://support.ptc.com/appserver/cs/software_update/swupdate.jsp
