How to remove Intralink parameters in Creo models
VladimirPalffy
Sometimes you need to clean up CAD data before sharing it with a third party or you would like to update Start parts templates and remove old PDM parameters.
You need to Set config.pro options:
dm_emulate_ilink_sys_parameters=yes
allow_create_pdm_param=yes
Best Regards,
Vladimir Palffy
bwyman
(To:VladimirPalffy)
This is great! I can update our company start part/assembly, but why do I have to be offline?  I need to be able to checkout the start files from our Windchill, remove the dead intralink parameters and then check back in.
*edit*  Nevermind, I made the changes offline, then reapplied the server and added them to the workspace they were checked out in to check-in the modified versions.
Hi, thanks for your note.
If I need to update start files that are stored in Windchill, I use the process that I download files to local hard drive and then I remove parameters.
After update start files - I will update data in Windchill.
Your process of using Offline mode is also good 😉
Thanks again and have a nice day.
Best Regards,
Vladimir Palffy
