Is it possible to save versioned files to a relative directory?
SOLVED
Visitor
Is there a config setting that controls where versioned file backups are saved using a relative file path?
Ideally, when I hit ctrl-S, a new file without a version number would be saved in the working directory, and the versioned file would be saved to ./archive. I'm always purging the versioned files to keep my working directory cleaned up, but then if I need them, they're already gone. If I could automatically keep them in an archive folder, that would help my workflow.
Re: Is it possible to save versioned files to a relative directory?
I think Creo fundamentally saves files with version extensions regardless.
You might consider a mapkey to perform a backup of the current file to a archive location then purge the working directory.
Alternatively, you would write a batch file that a mapkey could also run to perform the necessary operations I think without much trouble.
Dave
12 REPLIES 12
Dave
Thanks Dave, I was hoping for a config option, but a mapkey and/or batch file should do the job. Is there an environment variable that CREO recognizes for working directory? I did some digging, but couldn't find one. I expected $WORKINGDIRECTORY or something along those lines.
I am not aware of a config.pro option for either of those.  I think it has been that way for some time
You can set the working directory on startup of the application.  But that is typically done in the shortcut you create to the actual creo startup.  My example is like this:
Alternatively, you can create a custom batch file for the startup of Creo (most do), and set your working directory as the start location also.   You could set an env variable in that if you needed it for something else... but typically those are only local to the batch file's execution as I recall.
I would be curious to see if anyone as any other suggestions on this issue.  I am sure it is not uncommon.
Dave
Hmm, having a static working directory set at startup isn't very effective for me. I generally jump around between different folder structures within the day, so I'll reset my working directory to wherever what I'm working on at the moment is stored. I bet if I dig into the trail files, I can figure out how creo is handling that and come up with something.
Well remember - it is the "starting" directory ... we also change to about 10-different directories throughout the day.
But if you wanted an archive old files type of capability (instead of a strightup "purge" of the folder to keep old versions from sight)... then you may have to look at either a mapkey to do the process you are looking for... or have another program externally monitor and do stuff with the files in the background (external to Creo).
PowerShell may be an option:  (but admittedly would require some effort to get things the way you wanted).
https://superuser.com/questions/226828/how-to-monitor-a-folder-and-trigger-a-command-line-action-whe...
But the PowerShell option -- could conceptually:
scan the target directory for the highest file extension or most recent modified date,
then get all the other files with the same rootname.ext and ultimately
copy them for you to an archive sub-folder...
I think that may work.
Dave
I think I'm getting close with a mapkey. It looks like I can set "save_file_iterations no" in my config.pro to prevent versioned files from being saved to my working directory.
Then I can make a mapkey that will explicitly save to my working directory (which will set the current directory there), save-as backup to a relative path of ./archive from my current directory creating a versioned file, then somehow switch my current directory from the archive folder back to my working directory. Changing how I save files seems potentially dangerous, so I want to do a bunch of testing to make sure that this will work in all the various circumstances that I could run into. It's almost the end of the day Friday though, so that's a project for next week.
Actually, this seems to be working as intended:
mapkey save @MAPKEY_NAMESave to working dir, save versioned file to archive, purge working dir;@MAPKEY_LABELsave;\
mapkey(continued) ~ FocusIn `main_dlg_cur` `proe_win`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` `main_dlg_w1:PHTLeft.AssyTree:<NULL>`;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelSave` ;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelBackup` ;\
mapkey(continued) ~ Select `file_saveas` `ph_list.Filelist` 1 `archive`;\
mapkey(continued) ~ Activate `file_saveas` `ph_list.Filelist` 1 `archive`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ FocusIn `main_dlg_cur` `proe_win`;\
mapkey(continued) ~ Key `main_dlg_cur` `proe_win` 9 302 541 1179648 1024 1529 764 1920 1080 173568 `F4`;%$F4;
The "archive" folder needs to be created in advance, and F4 is a shortcut that runs a purge script. I'm getting double versioned files in the archive, but that's not a big problem. I don't know if this is better than my current method of dealing with versioned files, but I'm satisfied for the moment.
I hope you know the functionality of Backup command. It creates a copy of model and set it as "current" ... this means any following modification is saved into backup copy (not into original model). Therefore after finishing backup you have to erase model from session and open original model, again.
Martin Hanák
Doohh... Martin is right.... I guess "backup" does not mean "backup"...  This is one area of Creo where the words and behavior don't seem to perfectly align with intent.
Well... I would defer to a script to execute via mapkey to perform the operation instead.
Dave
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
