Check out this video on Model Based Definition from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow).
Click here for
Webcast Q&A
Question from Juan: What is the ideal way to share an MBD model with vendors? What config should we have set up in Creo?
Answer: Creo View with a .pvz out of Windchill or directly from Creo Parametric.
Step file and 3D PDF if you are not allowed to supply native Creo data.
