Any one knows how to lock any option in config.sup file. I have multiple options which i needs to lock in config.sup
thanks and regards
Nimish
If you add an option to the config.sup, it "locks" it for the creo session that is loaded. A user can not change that option in the config.pro or in the options dialog boxes.
Be careful about adding too much to the config.sup
