Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Understanding & troubleshooting Mechanism warning "The highlighted connection(s) are not defined from two bodies, if you continue they will be suppressed"
No ratings
Explanation of this warning and overview of 2 troubleshooting methods to resolve it.
