Check out this video on Creo 9.0 from PTC Application Engineers
Presenters: Jason Petersen (Technical Specialist, Principal) Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
Hello Lino
Can we make mill surface with the split method in manufacturing?
Regards
Pushkar Khanna
WEBCAST Q&A
Question from Artug: Is Keyshot 11 not supported by Creo 9?
Answer: Keyshot 11 will be added in future versions of Creo.
WEBCAST Q&A
Question from Brian: What type of curves, not just rectangles or circles?
Answer: You can use curves to project, curves, lines, splines, etc.
WEBCAST Q&A
Question from Dietmar: In assembly view, can I set parts to semi transparent?
Answer: Starting in Creo 8.0, you can pick any body or component and "make transparent".
WEBCAST Q&A
Question from Joe: Any new tips to create a product label without using images?
Answer: You would need to pre-build your sketch and use it as opposed to use a label.
WEBCAST Q&A
Question from Joel: Does the "make inseparable" command preserve the parametric flexibility (created through Pro/Program) of subcomponents?
Answer: This creates a new file with many caveats. A large window pops up with many of those caveats. Pro/Program commands may be lost.
WEBCAST Q&A
Question from Jon: With split surfaces, can you apply hatching for Datum Target area within MBD?
Answer: Yes.
WEBCAST Q&A
Question from Sergio: Are welding symbols improved?
Answer: Yes, there were some improvement.
