I can't display legend using Creo Simulate Live
Maggy
9-Granite
1 ACCEPTED SOLUTION
Hi Maggy.
This is likely due to you having anti-aliasing on. Please turn this off and the legend will appear. We will be addressing this for the production release.
Happy New Year.
Mark.
5 REPLIES 5
Hi Maggy.
Happy New Year.
Mark.
rgorny
6-Contributor
(To:mfischer)
I have the same problem but it cannot be solved by turning the antialiasing of!
Are there special settings you recommend?
I use nvidia driver version 391.74 with a quadro k3100m graphic card.
Thank you for your help
Regards
Ralph
Maggy
9-Granite
(To:rgorny)
My graphic card is NVIDIA Quadro M1200. Turn off antyaliasing makes the legend is displayed on my computer. I didn't make another changes. Maybe try to start Creo without any configuration file.
Regards
Maggy
rgorny
6-Contributor
(To:Maggy)
Thank you for advice. I started without config.pro and it worked.
So now is the question:
Which config.pro option influences simulation live?
Regards Ralph
hi @rgorny,
Can you share your config.pro file with me at mfischer@ptc.com?
I would like to take a look and report back.
Mark
