Prior to Creo 4.0. when a cable or wire failed due to violation of a fixed length there were not any tools to remove the fixed length of the failed feature.
With Creo 4.0 from Model Tree, or notification center you can now Right Click and choose Remove Fixed Length. If the wire has already failed then the fixed length is automatically removed, and wire is regenerated - See the attached Video
