Creo 2 M020 on Windows 8
Highlighted
Has anyone experience using Creo 2 M020 on Windows 8? In particular:
  • Was the installation on a new PC with W8 pre-installed or W8 installed over an earlier version of Windows?
  • Does it install and run OK?
  • Does configure.bat work, setting up BS8888 drawings and mm/kg/sec units properly?
  • Does plms4schools.bat run OK and allow learning connector to connect to the schools PLMS server?
  • Did you have any graphics problems?
  • Were you able to find W8 drivers for your graphics card?
  • Did you have to use the OpenGL switch to get graphics to work?
We are beginning to get enquiries from schools and early feedback would be most welcome.
2 REPLIES 2
Highlighted
Re: Creo 2 M020 on Windows 8
Mark Fischer has just updated me and PTC is supporting Creo 2 on Windows 8 from build M030 onwards. Mark will begin updating the download links for schools with M030 today so you should be able to download an M030 install image next week.
Highlighted
Regular Member
Hi All
I was running Cero 2.0 on windows8 at the trainer event at Vax the other week and so far have not come across any issues with the software. If anything it seems marginally quicker.
Drivers and 3rd mouse button no problem and easy to set up.
Creo standards just same as in win7 with permissions.
Will keep informed if experience any issues.
SImon
