Mini tripod for single extruder
Highlighted
Building on the feedback from James, I modified the parts for 3D printers with a single extruder.
  • Cap - Has a flat top for building upside down as shown above.
  • Leg - Split in two for gluing together after printing.  Only two halves shown.
  • Centre boss - Has the lower rounds removed. These would need machining or hand finishing after printing.
The unknown is whether the approximation for an Acme thread will build properly without support.
I also changed the leg clamp pattern to allow the legs to be set at different angles to cope with sloping surfaces.
Please leave feedback here if you build a set of parts.
