Parametric and Illustrate licence install issues
Highlighted
I have been contacted by a school having problems with installing Creo Illustrate. It is supposed to pick up the licence from Parametric but doesn't. They have copied the licence path from Parametric into Illustrate manually but still it doesn't work. I had this problem on my stand alone laptop and the manual process described above worked fine.
Has anyone else had this problem and if so how did you solve it?
Many thanks.
Andy
2 REPLIES 2
Newbie
Re: Parametric and Illustrate licence install issues
For some reason, I find it has to be the full pathname. Including the file name of the license file. I copy and paste it all into notepad first, then paste in the startup box for illustrate.
p
Many thanks for the reply. I will contact the school and let them know.
Andy
